03-25-2022 02:20 PM
My referral code would not be accepted when my sister was setting up her new account today. We tried many times. She did not get her $10 credit and I will not receive my $1/month credit. Please advise.
03-27-2022 07:54 AM
unnecessary repetition
03-25-2022 03:52 PM
Hmmm. Why avoid? Less referral, more $ to Public Mobile. 😋
03-25-2022 03:49 PM
Lol it seems like they do 0 and O a lot which you think they'd try to avoid. The referral code I used was the same
03-25-2022 03:43 PM
@CountyDownIeUk wrote:In your conversation with a CSA I would suggest that you copy and paste the referral code from your My Account.
Shouldn't they do that while signing up? Retyping could introduce typos. And looking at my referral code on top right side of account page if I had to manually enter it most likely would make a mistake as I have 0 and O as part of the code.
PM could at least make it bigger.
03-25-2022 03:23 PM
If she already opened account without referral code, she has to contact agent for manual entry.
And if you do not see similar to this below when you log in to My Rewards, that will be a confirmation referral code did not work or incorrect one was provided.
03-25-2022 02:50 PM
If you are on the Points system (activated SIM after January 25/22), you will get 1 point for referral reward but if you are an old member, you will get $1 discount/month.
Your sister should get a one time $10 off her second bill, it may take 72 hours to be added to her account as available credit.
Common mixup is with 1/I and 0/O numerical/alpha but suggest you contact a CS_Agent by private messaging or Chat on this Community page.
03-25-2022 02:33 PM
03-25-2022 02:22 PM
It could be just a typo, like 1 or l / 0 or O. But no worry, P Support are usually very understanding. Simply open a ticket with them and explain what happened, they will usually ok to add it back for you.
1. If you have access to Self-Serve My account: For faster response (2-48 hours) , Click on the bubble in the lower right to request CS Agent assistance, or use this direct link: https://publicmobile.ca/chatbot.
Start with typing "Submit a ticket", click "Contact Us", click "Other" from the choices, click "Click here to submit a ticket". Then follow to complete the ticket submission.
2. If you don't have access to My Account or have trouble with above method: you can Send a private message to the CS Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
**Monitor your Community inbox, envelope on the top right, after ticket is opened. CS Agent will reply and work with you via messaging there
03-25-2022 02:22 PM - edited 03-25-2022 02:23 PM
