refer a friend $10
helloaa
Hello, I refered friend and I haven't received $10.
How long it will take ? Or why I didn't receive?
@helloaa
If you gave out your referral code, you only get $1/1 point depending on what reward system you are on…not $10.
Your friend who used your referral code will get $10 in 72 hours.
DennyCrane
@helloaa You get $1 or 1 point per month for referring a friend. The friend gets a one time $10 credit.
@helloaa  If you referred a friend they should see the one time $10 credit in their account (available funds )with in 72 hours after activation . You for referring them should see $1 or 1point with in 24 hours of the activation . What rewards are you on . Old legacy rewards or the new point system ?
