03-30-2022 11:12 AM
I can send text and make call. However, people could not call me. It sends them directly to my voice mail.
I wonder what is going on?
03-30-2022 02:26 PM
@wwonderful1994 You'll need to submit a ticket to customer support then if the suggestions didn't help. Here's a couple of links, first try the chatbot: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
Second option if unable to submit a ticket send a private message here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
03-30-2022 02:15 PM
Still don’t work
thanks though
03-30-2022 02:15 PM
Still don’t work
03-30-2022 01:05 PM
It seems that the Telus outage is still affecting more customers.
Try powering off the phone, remove the SIM tray, reseat the SIM, wait 2 minutes, slide the tray back into the phone and power on the phone.
You can also try putting the SIM in another phone and follow the above instructions then put the SIM back in the original phone.
If that fails, contact a CS_Agent to refresh the network setting for your SIM.
03-30-2022 11:42 AM
Same here.
03-30-2022 11:19 AM
Whereabouts do you live?
03-30-2022 11:15 AM
Try removing the sim outta your phone...then reinstall it again. Others have reported similar issue as you.
Try Airplane mode ON...then OFF.
Good luck.
03-30-2022 11:15 AM
A lot similar reports over last few days.
One of solutions is to put your SIM into another phone which will trigger re-provisioning of your SIM/account and that might resolve your issue.
If issue is still not resolved you will have to contact agent for assistance.
