porting/esim issue
ericrleung
Accidentally put physical IMEI instead of esim IMEI. Sent a private message to CS_Agent but can't call other numbers since the number no longer works.
2 REPLIES 2
HI @ericrleung
call the porting support team.  I will send you the phone number to your Community inbox
@ericrleung
There is a number to call to talk to live support and update the info,  they can re-trigger the process for you.  I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) .  Check the envelope icon on top right.  Call them and get it fixed
