port out no sms
freek
@Typhon OHI while you think Oracle is the reason you don't get any rewards , actually, this month the system has issue with giving out rewards, and maybe that is the reason?
@freek
PM is owned by Telus and Telus is a publicly traded business.
Enjoy the service  🙂
DDM69
Okay.  Bye!
Hi @freek   are you porting into PM or poring out ?
if you are porting out, you need to contact your new provider to re-request
@freek  you are trying to port your public number out to another provider?
If so, you should really have a public sim card and your public account needs to be active in order to port out (exception perhaps to telus or koodo).
If you lost your public sim card, and have an active account here...you could try opening an account with another provider and ask CSA to give your new provider consent via a ticket to them. Don't know, but worth a shot.
Public Mobile Representatives customer support agents (CSA) can be contacted by either two methods, found here:
