09-17-2021 07:53 PM - edited 01-06-2022 03:33 AM
i dont receive picture that send to me by txt ?, how can i solve this problem, thankyou
Phones
09-21-2021 04:07 AM
Yeah you don't need to have data you just need it turned on in your settings.
09-17-2021 09:11 PM
check settings as per S--S
make sure your Data is on.
09-17-2021 07:59 PM
you have to Changing APN Settings,
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit Here link,
click Here link,
- Open the Settings app on your Android.
- Scroll to and tap either "General management" or "System," depending on what device you have.
- Tap either "Reset" or "Reset options."
- Tap the words "Reset network settings."
or visit Here link,
and go Changing APN Settings On Android device
click Here link,
Ensure you have the correct APN settings by visit Here link,
and do Rebooting your phone
*what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
for iphone go to Settings > Messages > To turn iMessage on or off,
Turn your data on to send a Picture Messaging in world-wide,
if your data is off and your home internet wifi is on is not going through the Picture or a video Messaging,
you have to do this to is going through you will need to turn your data on to send a Picture or a video Messaging in world-wide,
09-17-2021 07:58 PM
thankyou
09-17-2021 07:56 PM
@telecom To receive MMS, make sure you have Mobile Data enabled.
09-17-2021 07:56 PM - edited 09-17-2021 07:57 PM
@telecom wrote:i dont receive picture that send to me by txt ?, how can i solve this problem, thankyou
Make sure cellular data is on and your apn settings are correct.
