06-04-2023 02:42 PM
06-04-2023 05:35 PM
Did you just port your number to PM recently?
Did you reply to the text confirming you are porting over to PM?
06-04-2023 02:51 PM
Are you physically in a location where you were always previously able to make and receive calls?
What do you hear when you dial 611 (try that, it may work...)
Can you still text in and out (SMS, not iMessage or any other RCS type service...)
06-04-2023 02:49 PM
Do you have your network connection set to automatic? What network are you connected to (5g, 4g, 3g)? Do you know if your device and account are VoLTE enabled?
06-04-2023 02:47 PM
existing customer, new problem. Account is active, tried all the suggested solutions, no luck
06-04-2023 02:47 PM
@ormyboy if you don't mind , check My Account using Incognito mode once again just in case you were reading cached page
if status active, confirm if data works, try reboot the phone
try in different area in case it 8s local network issue
if you have another phone, test the PM sim there. It will force a sim provisioning and could resolve the issue
06-04-2023 02:45 PM
More details needed. Are you a new customer or existing and this is a new problem? Does texting and/or data work? Have you tried resetting your phone? Do you have an active network connection? Are you in Canada? Have you logged into your account to ensure it's active?
06-04-2023 02:44 PM
