06-04-2023
03:13 PM
06-04-2023
07:28 PM
computergeek541
@CS_Agent I am unable to make or receive phone calls. Text and data work fine. Please help.
06-04-2023 05:32 PM
Did you just port your number to PM recently?
Did you reply to the text confirming you are porting over to PM?
06-04-2023 03:31 PM
check My Account using Incognito mode once again just in case you were reading cached page
if status active, , try reboot the phone
try changing preferred network type to 3G only
try in different area in case it 8s local network issue
if you have another phone, test the PM sim there. It will force a sim provisioning and could resolve the issue
06-04-2023 03:29 PM
Try switching you device to 3G only in the network connections to see if calling is possible.
Or select "automatic" in those settings...
