phone randomly goes into no service
07-03-2019 01:40 AM - edited 01-05-2022 05:42 AM
My phone randomly goes into no service at home. It started 2 days ago I have used it at home since I started with public mobile about 6 months ago .If I re start my phone it goes back to normal.
Joining Public
07-09-2019 02:34 AM
@AngelczK wrote:There's many factors that could be causing this issue.. It could me your phone network settings, hardware or you could be located in a non-sevice zone.
Any speicific ideas that could help point this person in the right direction?
07-09-2019 01:04 AM
07-09-2019 12:54 AM
@darinamber wrote:tried it another phone same issues . Its a newer phone and dont have any other issues with the
phone . I get less bars now at home than i did when i first started with PM
@darinamber If the behaviour is consistent across phones then it could be an account issue. Best to notify PM of the problem.
To contact Public Mobile click here. The link sends you to the private message function and adds the moderator team as recipient for a private message. You just have to enter a title and text in the body of the message describing the problem and post. The message will be received by the moderator team and they will respond to it. You will receive the response in your private message inbox.
Moderators are available: M-F from 8 AM to midnight Eastern time and S-S from 8 AM to 10 PM Eastern time.
Note: Moderator Hours are subject to change, but you can always find the current times here
07-09-2019 12:38 AM
07-09-2019 12:37 AM
I tried it another phone same issues . Its a newer phone and dont have any other issues with the phone . I get less bars now at home than i did when i first started with PM
07-03-2019 03:12 AM
Hi @darinamber , as per @Dunkman , it might be a phone issue not a network issue. Public Mobile is on Canada's largest mobile network since they use the same network as Telus. Me personally, I recently just switched from Fido to PM a couple of weeks ago and I now have better coverage than before. I used to have no signal on elevators and basements with Fido but now I do get signals on both ever since the switch! 🙂
07-03-2019 01:48 AM
Do you have an extra phone at home? Try the SIM card in another phone to determine whether hardware issue versus PM Service issue.
