03-01-2021 09:48 AM - edited 01-05-2022 05:27 PM
Hi,
I requested to transfer my number. Currently, the data is working and i am able to calling out. However, all the incoming calls and messages are still on the old provider. It has been two days like this. Can you please assist?
My phone number is xxx-xxx-xxxx
Thanks,
Lelan
Edit by Dunkman: removed personal information
03-01-2021 10:42 AM
As mentioned above, your port is stuck. Fastest way is to contact Telus porting team as described above.
Here is some additional information on porting:
03-01-2021
10:00 AM
10-05-2021
08:29 AM
Dunkman
Try rebooting, removing and reinserting SIM card.
If that doesn't work, call the porting helpline at 1-x for trouble with porting.
It's not available for any other account related inquiries.
03-01-2021 09:57 AM
You should remove any of your personal information by clicking on the three dots on the top right corner.
You would need to submit a ticket to a moderator.
Here’s when and how to contact the Moderator Team:
