Unregistered sim
Pedrin
Just wondering my phone is not working
edited by computergeek541:  changed category (discussion isn't related to Community)
1 REPLY 1
slusagm
Turn off phone .  Remove the sim card and wait a minute and put it back and power on
You can also call 1855-4PUBLIC from another phone and check if account is active
If you need further help from PM, open a ticket.   Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
https://productioncommunity.publicmobile.ca/t5/notes/privatenote
