phone plan
slupjohnb
today i tryed to change my plan to a 5g plan. it gharged my credit card but i don't think it was completed
edited by computergeek541: changed category label as discussion isn't related to Community
@slupjohnb
CSA_PM (PM customer service ) did sent you an earlier private message. Need to respond to that message.
However, CSA_PM may be getting off shift soon and usually don't work over the weekend. If you are in conversation with CSA_PM, they should be able to help.
If they are not available at this time, then you may need to send a private message to CS_Agent as described earlier.
P.S. I will combine your duplicate threads.
A Public Mobile agent tried to each you earlier.
Click your Avatar picture,  to see the message they sent you and respond to it.
Click messages,  and then inbox or the envelope ✉️ upper right corner.
Socrates8567
Just know, they will try to offer you a credit to your account, and not a refund. A refund for some reason is a longer process. If you do ask for a refund, make sure you watch your credit card for the refund payment.
Please use the chatbot or direct link to contact a csa. They will reply to your mailbox here.
Yes, PM will help
 Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
https://productioncommunity.publicmobile.ca/t5/notes/privatenote
slupjohnb
Today I tryed to get a new 5g plan.i entered my credit card number and was charged 44.80. I would like that refunded as i didn't finish trying to get the plan. I find this very confusing.
CSA_PM
Customer Support Agent
Hello there.
I sent you a private message.
You can view and reply to it by accessing this link:
