a month ago
I have no network in my phone , tried all which your app says , google says , chat GTP says … please help, I am out of Canada
a month ago
a month ago
That is expected. PM does not have roaming service in Europe at all
It only has it in USA and Mexico
a month ago
I am in Europe and no network at all
a month ago
Public Mobile services does not work outside of Canada without proper plan or add-ons.
Which plan do you have?
a month ago - last edited a month ago
If you are outside of Canada, you are roaming. Public supports roaming in the US with Can-US plans and add-ons. Also supports Mexico with Can-US-Mexico plans. If you are somewhere else then you'll have to look for other options. So to start do you have one those plans or add-ons? If so, then you need to enable roaming on your phone and if it doesn't automatically connect to a roaming partner, then try manually connecting.
