phone not allowing calls in or out
abonertz
my phone has stopped calling out or allowing calls in, only texting can be done
What do I do? Would it be the phone malfunctioning or is something amiss elsewhere?
edited by computergeek541: changed category label as discussion isn't related to Community
8 REPLIES 8
hi @abonertz
Yes, iPhone 6S just does not make it to the list, you need an iPhone 8 and above to use VoLTE for more stable voices.
and a new iPhone will definitely solves the problem
abonertz
Hi there,
Its an old IPhone6 S. I have already ordered a new phone. Another friend had the same issue with an older phone.
Buying a new phone solved their problem.
hi @abonertz
that might be a VoLTE issue.  What phone is that?
and check if it is on the VoLTE whitelist
https://www.publicmobile.ca/en/get-help/articles/volte
abonertz
hi htideGnow,
I have already tried the CSA_PM, no resolution
I think the phone is too old
HI @abonertz
you have checked your community inbox and reply CSA_PM? they can help
abonertz
hello,
I have rebooted the phone several times and reset network settings, still not able to receive or send calls, only texts.
I think it may be the age of the phone.
CSA_PM
Customer Support Agent
Hello there!
I sent you a private message.
You can view and reply to it by accessing this link:
hi @abonertz
where are you ? not sure if you are impacted by this Reginal issue
https://productioncommunity.publicmobile.ca/t5/Get-Support/Active-Wireless-Degradation-Surrey-and-En...
But try Reboot phone and Try Reset Network settings
and confirm if you can use mobile data and if SMS text works
