11-11-2021 10:35 AM - edited 01-04-2022 05:13 AM
I didn't change anything on my account of Public Mobile. And my credit card works well. My phone was suspended yesterday with a message below:
"Please disregard this message if you have enough funds in your balance or are on AutoPay. Your account has been suspended. Make a payment to reactive your current plan.Suspended accounts are deactivated after 90 days of non-payment and you will lose your phone number and service."
What should I do to solve the problem?
11-11-2021 12:01 PM
@irene2021 let us know how it goes. Yes, Autopay are usually working well and it does fail occasionally. That's why some people would manual pay ahead of time. Once you put enough fund in the account, PM will take money from your account and you don't need to worry an Autopay failure (but still have Autopay enabled to take advantage of the $2 off)
11-11-2021 11:57 AM
Please keep us posted @irene2021 . You will know if the problem lies with your Credit card if the one-time payment also fails to go through.
11-11-2021 11:48 AM
Thank you very much. I will try your suggestion.
11-11-2021 11:28 AM
go sign in to Self-Serve, to review your account,
1. Click on Payment
2. Make a Payment
3. one Time Payment
4. you will see your Amount Due:$$
5. Payment Type: selected other ( Enter the desired payment amount )
6. how much you see at Amount Due:$ ! you will do manually enter Amount:$$ + $1 extra
what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
and if still not fix it follow this,
what is mean for Rebooting the phone means to turn off your phone about 2 minutes and turn it back on.
11-11-2021 10:56 AM - edited 11-11-2021 10:57 AM
@irene2021 wrote:I didn't change anything on my account of Public Mobile. And my credit card works well. My phone was suspended yesterday with a message below:
If you still have all your services working, don't panic.
So, if this is the case, ignore these messages on your SELF SERVE account.
I am not sure why Public Mobile does this, but it happens to me (and all of us) as well. It is part of the renewal process. Your self serve account will say Expired/Suspended the day before (edit: and morning of) they take out the payment. But it will be normal looking later today and tomorrow - until your next renewal.
11-11-2021 10:50 AM
Do you still have a service (calls/SMS)?
What your account says when you log in into?
Did your credit card get charged?
11-11-2021 10:42 AM
@irene2021 first of all, confirm if you have service on your phone.
If not, then login to My Account and check the account status and confirm if it is suspeded.
If so, then likely Autopay failed for whatever reason. It happens sometime. Now, you will have to make a manual payment
Go to the payment tab, click One time payment
first try to pay by Amount Due, if it works, good (if not, then try to pay by "Other" and enter the plan amount +$1)
once payment gone through, check if there is any button "Reactivate current plan", if so, click on it (if not, it's ok)
then logoff from My Account, and reboot your phone and you should be good
11-11-2021 10:39 AM - edited 11-11-2021 10:43 AM
Is your service still working?
If yes, there is nothing to worry about. The plan is in the process of renewal and money will be debited from your Available funds or credit card. Sometimes it could be running late but eventually, everything will return to normal.
If you've lost service,the Autopay has failed. Log into your account and check if there is enough funds there to cover the cost of the plan. If No, top up via your credit /debit card (or a voucher) and click on the Reactivate button if you see one. If Yes, then try to Suspend then Resume service (Lost/Stolen page) to reactivate the account.
