password reset from self-service seems broken again!
ErnieC88
@ErnieC88 wrote:
Thanks.....if I can't sign in, I cannot reach the moderator?
Ernie
The link provided a few years ago is out-of-date.  Please use this one instead:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html
The ticketing system has options to reset your password and for you to provide the customer support agent with additional account information to prove ownership of the Public Mobile account.
ErnieC88
Ernie
will13am
@ErnieC88 , you are not the only one with issues resetting the password.  Often the reset email never arrives or arrives stale.  You probably need to seek moderator team asisstance to do the reset.  The moderator team can be reached via private message using using smartforms which is initiated by clicking on the ? on the lower right corner of the webpage or try using this link. The guided process will facilitate documentation of the issue or concern and the required resolution which will be submitted to the moderator team. Refer to this announcement link for additional details on smartforms and the ticketing system for moderator team interactions. Refer to the following knowledge base article for additional information on the moderator team.
sunflowershine
@ErnieC88 See if the email sent to your spam or junk folder?
