PLEASE HELP ME!
Mellion
My iphone was recently broken I can’t log into my public account cause i can’t remember which email I used or the password but I need to access my public account to get into get into my iCloud which basically stores my entire life….
9 REPLIES 9
thepaladin68
You should reach out to Apple support for cloud/ account support. They probably would be able to assist you more at this moment
HALIMACS
You’re “ iCloud …  stores (your) entire life…. “
Whoa … that’s something.
I’m pretty sure Apple has a workaround to get your life back.
@Mellion wrote:
I need a code text to my public phone number in order to get into my iCloud’s I can’t get into my public account to transfer my number as my password is stored on my iCloud & it’s an eSIM
@Mellion
as said above, if you used physical sim card, you can put your sim card in another phone to continue receive text
Of course, if you lost your phone and the sim, then please submit ticket by direct message (not chatbot) using the link provided above
Mellion
@Mellion wrote:
I’ve tried contacting support it just goes in circles with the chat bot even when I click submit ticket
@Mellion
not Chatbot, please use this link below to direct message PM support
Mellion
@Mellion  Your PM account shouldn’t have anything to do with your iCloud that would be an Apple issue . But you can get support to help. You regain access to your account if forgot email or password option on log in doesn’t help .
send a  private message   To CS_Agents
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
@Mellion
if you used physical sim card, put your sim card in another phone, use Forgot login and Forgot password help on the login page and the text will send to your phone
if that does not work, since you don't even know your email used for PM EverSafe login, you can engage support to sort it out.  Message them here:
