Port Question
AmazingBernice
I spent 3 hours with a rep, and I have a temp phone number. How do I port my number now?
Yes, I understand that. Hence I edited my reply and forgot to remove the top part. Thanks for sharing.
@Chalupa_Batman wrote:
I will send you the porting team number and they will assist you. Check your mailbox top right corner.
If you log into your account, on the left side you click on profile, then you click on the pencil beside the temp number and follow the instructions to port number over to PM. Just remember to keep your old SIM card in the phone to get the request from your other provider. You will have 90 minutes to say yes.
As the customer has a tempoary number, there is no open port request.  The porting team cannot assist.  Whenever a port has been requested, the temporary number would have already been replaced.  The porting team will not initiate a porting request.
Chalupa_Batman
