password for voice mail
10-22-2024
05:10 PM
10-23-2024
12:46 AM
computergeek541
10-23-2024 07:55 PM
thanks @Nezgar
10-23-2024 07:44 PM
@slusagm wrote:@Nezgar what is the main difference?
Mainly that the first step after login is to now go to the "Profile" tab instead of the "Account", and slightly different wording on the button that does the reset.
Old steps according to the FAQ:
- Open the Public Mobile app or log into My Account.
- Navigate to the 'Account' tab.
- Choose ‘Reset Voicemail Password.’
- Follow the on-screen instructions to complete the process
The way now:
- Login to the My Account portal
- Go to the "Profile" tab
- Click the pencil icon next to "Voicemail password"
- Click the button "Initiate Voicemail Password Reset"
- Dial your own number to re-set it up.
10-23-2024 07:41 PM
10-23-2024 07:38 PM
@kc885 wrote:how to set
If you have never accessed your voicemail previously, then dial 1 or your own number from your Public Mobile phone to set it up for the first time.
If it is already setup, you can login to the My Account portal, go to the "Profile" tab, then click the ✏️pencil icon next to "Voicemail password", then on the next screen click the button "Initiate Voicemail Password Reset" - then dial your own number to re-set it up.
Unfortunately public mobile's FAQ still describes the voicemail PIN reset steps from the OLD selfserve portal. 😆
10-22-2024 05:15 PM
10-22-2024 05:11 PM - edited 10-22-2024 05:12 PM
if you have not activated your voicemail yet , press 1 on your dial pad to connect to the voicemail and follow the instruction
if you just forgotten your password then log in my account , go to profile and click reset voicemail password from there
