overcharged
_username312
I have been overcharged on my credit card from public mobile.
nethan
It might be a pending charge that's awaiting authorization, so let it settle. If it is still the wrong amount after being posted, then reach out to Customer Service Agents to have it reversed or credited! Hope this helps
@_username312
If these end up being Authorized/Approved charges and the extra funds are not showing in your Available funds area, then contact Public Mobile Customer Support Representatives (CSA) to have them investigate.
There are 2 ways to reach CSA, found here: https://www.publicmobile.ca/en/on/get-help/articles/contact-an-agent
HALIMACS
@_username312
It is likely what you may be viewing is a pending and authorized charge.
When Public Mobile makes charges to your credit card, especially upon activation, it may display as an unauthorized/pending charge.
This will drop off in a few days.
LoveNature
Hi @_username312
go to your account in front of the mien page do you see that amount at Available Fund,
if see it, then ok keep it for next cycle will be taken from there automatically.
DDM69
This forum is for questions.  Do you have one?  Are you looking for help?
Tsawwassen
If you believe you have been overcharged on your credit card from Public Mobile, you can take the following steps to resolve the issue:
  1. Contact customer service: explaining the situation and asking for clarification on the charges.
  2. Review your statement: Double-check your credit card statement and any other relevant documentation to make sure the charges are incorrect.
  3. Dispute the charges: If you have confirmed that the charges are indeed incorrect, you can dispute them with your credit card company. Most credit card companies have a process for disputing fraudulent or incorrect charges.
It is important to take prompt action if you suspect that your credit card has been charged inaccurately.
