01-26-2023 10:59 AM
I would like to add my Interac Card for monthly plan payments
Payment
02-01-2023 10:04 AM
You can try contacting customer service at About CS_Agent - Community (publicmobile.ca), hope this helps!
02-01-2023 09:58 AM - edited 02-01-2023 09:59 AM
Visa Debit will work
For login issue, you can try to Reset Password again using Incognito mode, enter any possible email addresses you could have used and see if it works. Check Spam folder
if not, PM support will be your friend then, please open ticket with them
1. Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
02-01-2023 09:55 AM
I cannot log in to my account. I have reset my password over three times already. What can I do
02-01-2023 09:53 AM
I have a debit Visa I would like to add to pay my monthly bill
01-26-2023 12:01 PM - edited 01-26-2023 12:01 PM
@Anna1962 Has to be as other have said only other option is vouchers every 30 days and 611
01-26-2023 11:22 AM
PM accepts only Visa/MC and VISA/MC debit. NO interact cards.
01-26-2023 11:07 AM
PM will take debit as long as it is a Visa Debit cards that have been issued by Canadian or American financial institutions and are associated with addresses in Canada or the U.S.
01-26-2023 11:01 AM
Does it have the Visa or Mastercard logo on it? If not then you can't use that debit card. Only the ones with Visa (and some Mastercard).
If so then you can log in to your account and change the card details.
