02-05-2024 04:15 PM - last edited on 02-05-2024 09:23 PM by computergeek541
Hi there
I ordered Public mobile SIM cards.
but received TELUS cards and they are not working.
and these SIM card numbers are not accepted by the PUBLIC MOBILE website.
because starting with 89122-30102-XXXXX-XXXX
they are not starting with 89122-30000-XXXXX-XXXX
Order 351133.
I need replacement SIM cards for PUBLIC MOBILE.
02-05-2024 04:47 PM
02-05-2024 04:24 PM
fyi...PM has esim available too...depending on which phone you have.
02-05-2024 04:20 PM
Yes I ordered them through the Public Mobile website. will connect to agent.
and received order confirmation from 'noreply@publicmobile.ca'
Thanks Phil I will try it.
02-05-2024 04:17 PM
@mktir You ordered them through the Public Mobile app/website? That's strange. Best to contact customer service using this link. An agent will reply at the envelope icon top right or tap your avatar for Messages if no envelope
