Is Picture Messaging included in U.S. $15 add on
Imre
I am planning on going to the U.S. later this month and would like to purchase a U.S. add on roaming package.  I see there are only 2 add ons available.  Does the $15 plan include picture messages along with texting or do you have to purchase data in order to enable that feature?  I know plans in the past have included picture text messaging but want to make sure before choosing the correct plan.  I would like to send a picture with the occasional text message from the U.S. to Canada and need to know if the $15 plan would include this.  I could not find any clear information on the site including this information.
Thank you
2 REPLIES 2
hairbag1
@Imre
to be sure you can send/rec MMS, I suggest getting the 15 Day US Roaming talk/text and data package ($30). I'm like you..can't find definite answer one way or the other. Make sure to enable Roaming Data in cellphone settings.
PhoneHome8932
See this post.  😉
https://productioncommunity.publicmobile.ca/t5/Get-Support/US-Roaming-add-on/m-p/1047787
You could enable RCS chats in Google messages  if you have an Android phone or imessage for Apple. When connected to Wifi you can send photos over the internet.
