11-17-2024 10:39 AM
Can't send picture messages now. I have been with Public for many years and it works in this phone no problem for years.
I already rebooted the phone but still not sending
11-17-2024 10:50 AM
ok, the update works. thanks
11-17-2024 10:42 AM
I already reset network
I will try the update
11-17-2024 10:41 AM
of course MMS is on
11-17-2024 10:41 AM
@Bartwo Did you accidentally to turn MMS off in phone settings
11-17-2024 10:40 AM - edited 11-17-2024 10:40 AM
hi @Bartwo
what phone do you have?
try Reset all networks firsr
But if you have an older phone from 2017 and before, it might be affected by some PM recent changes. Try this APN update :
APN: sp.mb.com
MMSC proxy: mmscproxy.mobility.ca
MMS port: 8799
MCC: 302
MNC: 220
APN Type: default,supl,mms
