not paying 17 dollars i need my 4 bucks rebate
mikemobile
i have 2 dollars loyalty which needs to be shown on payment and my 2 dollar reward
11 REPLIES 11
mikemobile
well good night i look for moderator
mikemobile
if you get this 404 then private message tgis is solutionIMG_20221129_221935 (1).jpg
 if you get 404 then private message goog might i did
mikemobile
r loyalty is 2 dollar loyalty as soon as i pay then 2 dollar reward for autopay this is the way it works ---i am short min 2 bucks and disagree with the glitches now moderator help to see the checkout page with it
mikemobile
loyalty 2 yeasr give me my 2 bucks and 10 days late now adding credit card i still want 2 auto pay reward
mikemobile
sharp---just give me my 4 bucks on my check out page i will not proceed
mikemobile
oh how sgarp u are
mikemobile
mo  i didnt why should i do so i still need my 2 bucks royalty and my 2 bucks i use credit card what is better in your view
darlicious
@mikemobile
Did you switch to the points program? Log into your rewards account and tell us what you see?
@mikemobile   why are you posting the same thing everywhere?
darlicious
@mikemobile
Are you reactivating? Otherwise if you are changing plans mid cycle and downgrading there is no prorating so no point in downgrading. Can you give us info on your current account status and choice of plan?
HI @mikemobile
are you making a Change plan now?  If you are a mid-cycle change plan is always like that, they won't apply rewards on "change plan now".  Rewards will only be applied during regular renewal, not when you "change plan now"
