11-29-2022 08:42 PM
i switches to another carrier today and my old phone number (from public) is not transferring over
11-29-2022 10:20 PM - edited 11-29-2022 10:20 PM
the porting system is broken you need to contact PM customer support
11-29-2022 08:58 PM
@dianeyu_ how long you reply yes? your PM still works? usually porting takes 30 mins to 4 hours
11-29-2022 08:50 PM
HI @HALIMACS
I think too many people porting around 🤣
but honest, I heard other systems are busy too
11-29-2022 08:50 PM
Can you still log into your PM account? If yes, the port has not been completed.
If you cannot log into your PM account it means the port was successful and you can put your new carrier sim in and reboot.
11-29-2022 08:49 PM
This is getting kinda ridiculous, @dianeyu_ as there have been several such similar kind of customers experiencing porting out issues.
Have you tried putting your new provider SIM card back into your device and rebooting it and resetting network connections?
If this still doesn't work, call the number I'll private message you. To view it, click on your envelope icon upper right.
11-29-2022 08:49 PM
11-29-2022 08:49 PM
i am porting out to freedom mobile. i called them and they said that the transfer says successful on their side
11-29-2022 08:48 PM
yes i had the PM sim in to get a confirmation text
11-29-2022 08:47 PM
yes i replied with Yes but did not receive a confirmation text after that message
11-29-2022 08:43 PM
HI @dianeyu_
is your PM account active when you request porting?
did you get a text from PM asking for your authentication to port? you replied YES? To make sure you can get the text, check if you can receive friend's text on your PM sim card
Also, for porting out, call your new provider and ask them for update or re-request porting from PM.
11-29-2022 08:43 PM - edited 11-29-2022 08:43 PM
@dianeyu_ They should be able to port in without any issue as long as your line is ACTIVE. Provide them your name, number and the Account Number. You can login to your account to obtain the Account Number.
What carrier are you porting out to?
_________________________________________________________________________________________________
If you need to contact PM Customer Support Agent, create a Ticket.
11-29-2022 08:43 PM
