no voicemail notification
WJJ1
No red dot on phone or voicemail symbol on Iphone 10. Worked with previous provider. tried toggling badges in settings/phone/notifications etc.
Can't get chatbot to work or response from CS_Agent.
Help
7 REPLIES 7
WJJ1
Just to update anyone that may have similar issue, after many go rounds with the previous CS agent, the most recent CS Agent suggested updating to iOS 16.6.1. (I thought I was at most recent because I had auto update turned on etc, but turns out I wasn't as I was on 16.11.) In any case good news, updating to16.6.1 seems to have solved it. Red dot is back!
WJJ1
Yes I have iOS 16.11.  I did get a response from CS_Agent so I will report if it gets resolved.
@WJJ1
It is probably iOS 16, there was reports from some Apple Community about the older iOS 16 software download but hopefully iOS 17 will help fix this issue with some iPhone users coming sometime next week.
WJJ1
After all the searching I've done I was getting that feeling from years ago, nut would of thought they resolved it by now.  We switched 3 family Iphones to Public a few months ago but am starting to wonder if the cheaper price is worth it considering the terrible (seemingly non existant) customer service.
WJJ1
Thanks, I have sent them a pm requesting the reset.
umnikke8
Voicemail notifications have always worked intermittently on my iPhone in all the years I've used Public. I've gone through support and all the resets have been done, it's still intermittent. Many others report the same issues. It's nothing to do with a specific iOS version, Public's voicemail system just doesn't work well with iPhone for whatever reason.
@WJJ1  Not sure if this is iOS issue .latest software 16.6.1 update if not already .or provider issues but some have said they had luck asking support to reset their voicemail . You can use this direct link to support to ask
send a  private message   To CS_Agents click
