No service
Pooks
I pay my bill each month but can't get service. Try to login to my account but am told I am locked out. I successfully changed my password (according to an email) but still can't log in. I am told I will get a security code sent to my number but nothing comes. Can't send or receive texts or receive calls at my number. It seems I am paying for nothing. Help?!
Pooks
Thanks everyone! I'm back in business for now and able to communicate with a friend gravely ill in hospital. So grateful!
@Pooks - how long had you had service up until this point?
When you call 611 (or # 1-855-478-2542 or # 1-855-4PUBLIC from another device)  what the status say?
Do one or more of the below may help with network issues:
As for the log in to My Account can you hit RESEND or enter the code incorrect a couple times to get the email option to log in? Or try the forgot your email option, see if that helps.
dust2dust
From another phone dial 1-855-4pu-blic and give it that number and see what it says.
Also have a look at devicecheck.ca to rule that out.
will13am
@Pooks , try using incognito mode on your browser.  If you are not getting 2FA to SMS, click on did not receive code and select email option.
JRod
@Pooks
After a few login attempts you should see a didn’t receive code option and be able to send the code to your email to login to your account. I would also try to reboot your phone and see if that helps.
@Pooks  Try rebooting the phone first , if still no luck please use this direct to support to investigate for you
send a  private message   To CS_Agents click
