Please HELP
Pierre50004
Please Help
Going by the first part of your username, are you aware that there's a French side to this site?
I'm not sure what has happened. Does anything work on your old sim? Does anything work on this sim?
JRod
I will send you the number to the porting department. They will be able to check the status of your port and assist with restarting it if needed. Also try rebooting your phone first before calling in case that fixes it.
Click this link to check your private messages:
Pierre50004
I did a portin number my provider send me a text all was good my number was working in both places but the cancel the porting presses an diactivat my services a public mobile I do not have anymore services
@Pierre50004
With what?
Or R U just 🎣
JRod
@Pierre50004
Hello! Sorry to hear you are having issues. Would you be able to share more details about what you are needing assistance with?
