05-09-2023 10:00 PM
I have an active plan. Today I changed my public mobile number to a new number and I also registered an e-sim on my iPhone 14 pro. And then I inserted public mobile sim into my phone and no signal from there on. Don't know what's happening. please help..
05-10-2023 01:09 AM
I already have an esim with another carrier in my phone. Being a dual sim phone, both the networks should work right. Anyway its an issue with PM card as I have tried it on multiple devices and still no signal. And thank you for providing me with the timing.
05-10-2023 01:04 AM
I was just curious why you need to activate eSIM and you are correct the PM doesn’t support eSIM.
Sounds like a provisional/backend issue with the SIM. CS_Agent hours are 6:00am to 10:00pm EST so the best time is to pm them in the morning and they should get back to you the same day.
05-10-2023 12:58 AM
Sure will do that. Any idea how long will it take to get a response from agent
05-10-2023 12:29 AM
@fjames02 if it does not work in another phone too, it is just a sim provisioning issue. Please message PM support and have them to investigate further
05-09-2023 10:54 PM
I bought the phone new. So not blacklisted. PM card was never used on this, but it was working on an Android device. Today I changed the phone number of my PM card and it stopped working on that Android device too
05-09-2023 10:49 PM
Public mobile doesn't support e-sim anyway. And I tried my PM Sim on another device as well. Still not working. I think it has nothing to do with e-sim. Don't know what to do.
05-09-2023 10:20 PM
What carrier did you register your eSIM with?
If it is with another carrier, you need to disable eSIM and switch to PM SIM.
05-09-2023 10:02 PM
@fjames02 do you have another phone to test the PM sim ?
And this iPhone 14 Pro is new and the PM sim card was never used on tihs? If so, please check if the phone is blacklisted
https://www.devicecheck.ca/check-status-device-canada/
(please remember you have 2 IMEIs on this phone, make sure you enter the one associated with the physical sim ad not the eSIM to check)
