no service
sheryn
i still have no service… shld have been ported from virgin to public… chat no help at all and link to submit a tkt not working
even codes need to be requested twice! so annoying
sheryn
resolved, thanks everyone
@sheryn wrote:
Yes, I  received and confirmed that text
HI @sheryn   since you have no service now, it is not a porting problem, but a sim setup problme
please submit ticket with agent at
sheryn
@sheryn
When you ported over from Virgin, did you reply to the text with YES with the Virgin SIM in the phone?
If you didn’t then porting is incomplete. You will need a CS_Agent to restart the porting process for you.
If you did, check for outages in your area:
https://istheservicedowncanada.com/status/telus/map
DDM69
Check your inbox for a number to call.
@sheryn  Message support directly
  • while your already here and logged in the community
  • you can send a private message   To CS_Agents by clicking >>>>>>>>here.
