My subscription is not working.
Leandro2006
I have no pending payments and my subscription is not working. I am able to receive sms to authorize logins but I can’t make nor send SMS and I am unable to make nor receive calls.
11 REPLIES 11
HI @Leandro2006 there is no live support
You are close to the end, just need a ticket, then PM agent reply via message.  You will get full service soon
@Leandro2006  Time to open a ticket
  • while your already here and logged in the community
  • you can send a private message   To CS_Agents by clicking >>>>>>>>here.
Leandro2006
Enless loop without anyone available to talk to. The chat directs me here and you direct me to the chat. I need someone locally in BC giving technical support to call me or I’m just canceling this service.
@Leandro2006  from the screenshot , you are connected
Then plese submit a ticket with agent.  They will reply in around an hour or quicker
LitlLdy
@Leandro2006
For your own privacy & security please remove your phone number from your post & do not post any private information here due to this is a public / open forum. Sorry
Leandro2006
@Leandro2006 wrote:
I’ve followed the instructions from the chat to reset my iphone network settings. Other than deleting all my wifi passwords, my subscribed services are still not funcional.
I can connect to the public mobile network, receive sms from the “public mobile page” exclusively but nothing more.
@Leandro2006   what phone do you have?
But since you got text, your phone is connecting to PM network
you can try to enable VoLTE on the phone to check voice
and is data working?
but you should start a ticket first while we try to help
HI @Leandro2006   for login problem, when you see them sending you code, click Resend Code and you should have Send email option in the screen after
Leandro2006
HI @Leandro2006   is that physical sim or eSIM?  did you request number porting?
try reboot the phone first
Try reset all networks
if it shows not connects to PM network, it is a sim setup problem.  Please submit ticket with CS agent
@Leandro2006  Try rebooting the phone or rest newtwork settings and can you try SIM card in another phone
Add please remove personal info tho sis public forum
