4 weeks ago - last edited 4 weeks ago
Hello,
I am trying to subscribe but when I login it just shows a pre chosen package and can’t choose any packages. It just shows a pre chosen package
4 weeks ago
If you are old subscriber, please create a new account using a different email address
4 weeks ago
Yes was a subscriber before
4 weeks ago
Hey @mehadihn
It's because you've used that email on your previous account. This is a simple fix. Use a different email address to sign up. Easy as pie. Then, go pick whichever plan you want. Remember, you must complete the sign up on the phone app.
4 weeks ago
hi @mehadihn
you were with Public Mobile before?
easy fix is to use another email to create a new account. But first uninstall the app, then reinstall and use another email address
