no service
AJMad
I have no service, can't make/receive calls or use data/text.  called my line from another number there is a message saying something about US roaming - I am not in the US - is there a system issue?
8 REPLIES 8
hairbag1
@AJMad
there's another similar question from a customer in Timmons....could be a network problem showing up in that area.
AJMad
@AJMad
It sounds like an outage in your area or you forgot to make a renewal payment for this month.
But check outage map:
https://istheservicedowncanada.com/status/telus/map
Meow
Did you try to force provider as PM? Turn off roaming?
AJMad
tried that - have two phone plans and both are having the same issue
@AJMad  reboot the phone and maybe tr to manually connect to public mobile
Annoyed123
Same here.
