no log
eric61
  • my account is locked
@eric61   try what @hTideGnow  & @hairbag1 suggested above.
And curious, what you meant by "no log" on your subject.  Are you trying to access log via My Account?  Let us know if further issue after you able to log back into My Account
hairbag1
@eric61
some more info would be helpful.
Is this for a new account or have you been a PM'er for awhile ?
When was last plan expire ? After 90 days suspended, your account is closed and deactivated.
Log in on a laptop using incognito mode.
HI@eric61   there is no more account lock now.  Just close all the browser and relaunch
You can try login again
or if you forgot password, use the password reset link to reset password
If you still cannot reset it, submit a ticket with CS agent and they will help
Please submit ticket at : https://publicmobile.ca/chatbot.
First type Forgot Login,
