Tuesday
Start subscription today and successfully ported my no. Everthing works except no incoming calls. Says the line (the no) is not assigned. Can somebody help?
Tuesday
hi @Clamqc
Did you get a text from the old carrier, did you reply YES?
and can you receive inbound phone calls, especially from Non-Telus/Koodo/PM phone? If you cannot the port was not done
It could be an incomplete port. PM porting support team can help. I have sent you the porting support team number. Please check your Community inbox (envelope on top right), check for the number and call
