Tuesday
- last edited
Tuesday
computergeek541
I did not answer to my original provider within the 90 minutes so my transfer did not go through, I called Rogers and they said you would have to request it again.
Tuesday
hi @Ddesj
PM porting support team can help. I have sent you the porting support team number. Please check your Community inbox (envelope on top right), check for the number and call
Tuesday
@Ddesj No worries I’ll send you the porting team number private message . They can re trigger the port request for you
Tuesday
@Ddesj I will send you another message with the number to request again. Please keep Rogers sim in phone.
