no connection new customer
Hawkshaw
Just transferred from Mobility.  eSim installed.  No connection.  iPhone 13 MaxPro
10 REPLIES 10
@Hawkshaw
glad it helped.
Yes, that's what the Community for.  We always try to help before asking people to talk to CS_agent, which is the longer route
Enjoy the savings 🙂
Hawkshaw
Primary was what I was missing
Hawkshaw
solution found thanks
@Hawkshaw
working now?
Hawkshaw
Excellent - thank you
@Hawkshaw
On iPhone: Settings->Cellular , make sure the PM eSIM is set as Primary on "Cellular Plan Label" and "Turn on This Line" is toggled on
and it helps to remove your old physical sim card from your old carrier, or if your old one was a eSIM too, please disable it (toggle off Turn off this line for your old carrier esim)
Hawkshaw
iPhone 13 MaxPro
How do I "clearly" see the PM eSim intalled.  ?
@Hawkshaw  here’s link for support
send  a  private message   To CS_Agents
Hi @Hawkshaw
remember, do not try to delete the esim if it is already installed, the deletion will cost you $5 🙂
Try to Reset All networks and test again
HI @Hawkshaw
iphone or android? and you clearly see the PM esim installed?
If it still does not connect and if you have another active sim on the phone, disable those non PM sim (eSIM/Physical sim) using the SIM Manager on the phone or simply remove the physical sim.
And make sure the one associated with PM sim and your phone number is enabled.
(On iPhone: Settings->Cellular , make sure the PM eSIM is set as Primary on "Cellular Plan Label" and "Turn on This Line" is toggled on)
Then click Reset All Networks on your phone and it will work.  (Please note that Reset all Networks will also erase your saved Wifi and Bluetooth connections, but you just need to add them back after). Also, it is possible you have to reset it multiple times for it to work.
if it still does not work, please open ticket with PM support
