no cell signal
10-24-2022 03:00 PM - edited 10-24-2022 03:02 PM
hello Public Mobile community,
need help, im recently experiencing call issues, been with PM for a few years now.
Account is Active and is in good standing. Hardware is unlocked Iphone X.
Cannot make or receive calls. If i reboot my phone I could make an outgoing call, but still not receiving incoming calls
Not sure where to start? I've initiated a service ticket this afternoon.
Thanks in advance
Service
10-24-2022 06:49 PM
@julielau57 hopefully it will all work out for you 😁
10-24-2022 06:46 PM
Thank you @RossN we opened a ticket, and still going thru the process.
Cell reception was still flakey when manually switching to 3G.
We have since, reset the network settings and things are working at the moment.
Fingers crossed.
10-24-2022 06:42 PM
@julielau57 hi your sim should be fine I am glad that worked but you may be having an issue in your area cantact a customer service agent to look into it for you
1. you can open a ticket through Simon here https://publicmobile.ca/chatbot.
2. alternatively you can private message them here
10-24-2022 06:38 PM
10-24-2022 03:13 PM
@hairbag1 yes good idea
10-24-2022 03:12 PM
@RossN thank you will try that.
Does this impact data speeds?
10-24-2022 03:11 PM
Swap sims to see if the it works in his phone.
10-24-2022 03:08 PM
@julielau57 hi try manually switching your network setting to 3g see if that helps with your phone calls ,they may be doing maintenace on the tower near you
10-24-2022 03:07 PM
10-24-2022 03:04 PM
Could be a local network outage or isssue. Where you located...generally.
