Options
10-23-2022 08:54 PM
Will changing your plan switch you to the new public points system or do I still keep my $credit for autopay, referral and loyalty rewards?
Moved:
Options
10-24-2022 06:36 PM
Options
10-23-2022 09:00 PM
Options
10-23-2022 08:59 PM
If you change plans, you will not be switched to new points systems. You will keep the old rewards as before.
