06-30-2021 01:33 AM - edited 01-06-2022 02:39 AM
my PM plan is lte and celluar wont load any pages when i am off wifi. 3 bars of signal but nothing will load but still able to make calls. Is it a bad SIM card or ??
07-10-2021 11:22 AM
06-30-2021 01:47 AM
@D2le : Can you check for mention of your data under My Data & Add-ons on your self-serve overview page. Maybe you've used all your data.
06-30-2021 01:40 AM
@D2le wrote:my PM plan is lte and celluar wont load any pages when i am off wifi. 3 bars of signal but nothing will load but still able to make calls. Is it a bad SIM card or ??
This could be an APN setting issue. I would suggest by starting here: Set up data on an Android phone (publicmobile.ca)
06-30-2021 01:39 AM
Ensure data is on and your apn settings are correct. You can also try resetting your network settings.
