12-05-2022 11:26 AM
Hi there,
I have a paid PM plan for 3 years and have been using the same SIM card. Recently, I can't seem to get any calls through and there's no network connecting in my phone even when the PM plan is paid and active.
I have tried the SIM card on another phone and it didn't work as well.
Are there any solutions for this?
Thank you.
12-05-2022 03:26 PM
HI @Biker47
try to click Reset all network and hope it works
Since it works on iPhone, it is really just a phone problem and not the account/sim card, I think
12-05-2022 03:23 PM
12-05-2022 11:47 AM
the phone is an Oppo andriod. and it worked just fine for a good year before this happened.
12-05-2022 11:45 AM
HI @Biker47
I think it might not be android phone or not but the model of the phone. It might have different bands
What make and model is your phone?
and this phone was working earlier?
12-05-2022 11:44 AM
Status bar - 1 bar only
My account status - active and still a long way to be due.
Mobile data is working - based in BC. Tried another phone plan from Kudoo and it's working fine. No local outage.
12-05-2022 11:42 AM
Android phones seems to be an issue, it seem to work fine in iphone that I borrowed to test it out. But my phone is an Android.
12-05-2022 11:41 AM
Since you tried your PM SIM in another phone and it is not working, it could be SIM issue.
Gently clean SIM contacts and try again.
Try other SIM in your phone to confirm it is not phone issue.
12-05-2022 11:35 AM
@Biker47 well , it seen to be the SIM card problem,, since you try to another phone.
12-05-2022 11:28 AM
Hi @Biker47 so, there is no status bar at all?
you check My Account? is status active?
and is mobile data working?
which city and province you are at? did you try to use your phone in another area as well? maybe just local outage?
I strongly suggest you to also only ticket with PM CS agent
at : https://publicmobile.ca/chatbot.
First type Forgot Login,
