01-29-2022
10:57 PM
01-30-2022
12:56 AM
computergeek541
I real appreciate any advice. Thank You Members. Jake
02-08-2022 04:11 PM
You are the first member to provide the Speakout info.
It is enough for me with the bravos on my thread from members reading my post.
02-08-2022 03:53 PM
Aw shucks! But really it's your original post relating your own experience porting from speak out to pm that's most helpful. So much so I was smart enough to tag it for easy reference. Had I known we would lose that option I would have tagged a lot more posts!
02-08-2022 03:34 PM
@darlicious wrote:I would surmise that you did not read the entire thread but I will speak out and say not even a lucky guess and a pm that ended with a bunch of chatr that should been archived by popping in with a solution by pointing out their own solution in post just above a popping post noting speak out too?!!
@darlicious is the first member to guess OP's previous provider is Speakout by his community user name.
After knowing the possible Speakout porting issue, I pointed out to OP to read the darlicious' first link on how to port a Speakout number to PM without CSA assistant. About 3 hours after my post, OP replied to my post about his Speakout number was ported successfully and confirmed by OP that he is porting Speakout number to PM. Darlicious' post should be the solution as she is the first to provide the porting Speakout info.
02-08-2022 12:10 PM
01-30-2022 07:53 PM
@speakout wrote:I real appreciate any advice. Thank You Members. Jake
Welcome to PM and the saving going with it.
01-30-2022 06:25 PM
what happened was Public Mobile ported my number, but it was rejected by speakout. ticket was created by Public Mobile and the issue is now fixed. Everything Works ! I really appreciate your assistance.
01-30-2022 06:18 PM
what happened was Public Mobile ported my number, but it was rejected by speakout. ticket was created by Public Mobile and the issue is now fixed. Everything Works ! Thanks.
01-30-2022 06:14 PM
what happened was Public Mobile ported my number, but it was rejected by speakout. ticket was created by Public Mobile and the issue is now fixed. Everything Works ! Thank You Very Much for your assistance. Jake
01-30-2022 03:07 PM - edited 01-30-2022 03:12 PM
Number porting is a 2 stage process:
Stage 1. After submitted your porting request, PM set up your old number on your PM account. Login to your account. Select the [Plan and Add-Ons] tab. Is your old number showing on the [Plan and Add-Ons] page?
If yes, PM has done its work to setup your old number for you to call out, send text and data.
If no, you should create a support ticket for CSA to investigate. CSA wait time is from couple of hours to couple of days.
Stage 2. Now, you are waiting for your old provider to release your number to PM. Not until your old provider release your number, all the incoming calls and texts will continue to go to your old provider. You can continue to use the old provider SIM card until it stops working which is the indication that your number was released to PM.
Mobile providers started to send out text message for you to confirm the port out request before releasing your phone number to PM. Did you leave your old SIM card in your phone so that you can reply YES to the port out confirmation text message?
If no, create a support ticket by clicking on the bubble at the lower right hand side of this page to send another port request again.
If you are porting from Speakout, read my writeup on the first link, provided by @darlicious post just about this post, for details. I ported my Speakout number to PM in 4 hours without CSA assistant.
01-30-2022 04:30 AM
Hazarding a guess by your username that you have ported from speak out. You may find these posts useful:
01-30-2022 02:00 AM
you said ported in the number successfully?
Check again the port in process.
01-30-2022 12:50 AM
Moto 5 - tried your suggestions. does not work. Thanks for writing. Jake
01-30-2022 12:49 AM
@speakout were you ever able to receive incoming calls since joining?
did you just join PM for couple days? you mentioned you ported your number, did you reply to the text from your previous provider with a YES? Can you try put in your old SIM in a phone to see if you still get full service (incoming and outgoing calls) on the old SIM with the old provider?
01-30-2022 12:48 AM
Thank you for all your info. Much appreciated.
01-30-2022 12:47 AM
did not work. Thanks for your response
01-29-2022 11:42 PM
Are you saying that number porting was successfull based on the on-screen message from the Public Mobile website? While Public Mobile uses the word "successful", that is not an indication that porting is complete or that it will work. It only means that Pubic Mobile has received your request and will be sending it to your old carrier.
01-29-2022 11:20 PM
@speakout if you have an iphone, and you activated with a different number used previously, deregister the number on the iphone: https://selfsolve.apple.com/deregister-imessage/
Set up your phone number On your iPhone:
01-29-2022 11:09 PM
01-29-2022 11:05 PM
@speakout - cell phone ports take 2-3 hours to complete.
Landline/voip ports normally take 3+ days to complete
Incoming calls are the last to port over. So your porting is likely acting normal.
See helpful info. here: https://www.publicmobile.ca/en/bc/get-help/articles/port-fraud-protection
If issues porting or transferring a number to Public Mobile, and it has been over the allotted time it usually takes to complete, submit a ticket here for help: https://widget.telus.tiia.ai/chatbot.html?botId=ZJkWuVb7Hp6EEcTIZKMZbvLwuDV&duid=1ml7MK2dvkmM37lFcEM...
01-29-2022 11:00 PM - edited 01-29-2022 11:10 PM
is data working?
try reboot your phone first
if still fails, try to put your phone's Network to 3G only and see if it helps
What brand/models is your phone?
