need someone to contact me asap
baljindersingh
 i can't access my account i need my account number to port my phone number out
8 REPLIES 8
jlfetsch
When I switched to Public Mobile I didn't need my old account information. I just kept my old sim card in my phone. When activating my new one, I got a text from my old provider asking if I consent to the number port. Of your PM account is still active, this might work for you.
baljindersingh
okay thank you !
@baljindersingh usually within 2 hours.  Keep checking your Community inbox
baljindersingh
tried nothing works  and i msged a cs agent how long does it take for a reply
LoveNature
Hi @baljindersingh
open a ticket with SIMon Chatboth
typ: forgetting information
and Click, Forgot My account Email
then Click, Contact Us
and, Click here to submit a ticket.
or send a private message to  CS_Agent
here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
@baljindersingh
did you try reset password yourself?
if that does not work, you have to open ticket with PM support and ask them to help reset the password
1.  Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
@baljindersingh - if you are porting out ensure your account is Active (unless going to Telus or Koodo).
Try clearing your browser's cache, or try a different browser or device. Or, open a tab in incognito mode and access My Account that way.
If having issues about which email you signed up with (if you did register for a My Account), use the Forgot your password option to reset it, found here: https://myaccount.publicmobile.ca/en/forgot-password
If an email is received (check spam/junk folder) then the email is likely registered.
If having issues with your password, use the Forgot your password option to reset it, found here: https://myaccount.publicmobile.ca/en/forgot-password
For My Account log in issues if continues, you can submit a ticket here to: Create, forgot or change My Account email or password link
@baljindersingh
  • Get support by starting a conversation with virtual Chat box /SIMon. Click here
  • you can send a private message   To CS_Agents by clicking here.
  Watch for reply top of page to the
   Right ( envelope image )
