06-08-2026
02:29 PM
06-09-2026
12:38 PM
Dunkman
i need to renew or upgrade my subscription, it stops me as it says "finish up activation"
06-08-2026 05:41 PM
@Roland007 wrote:yes agreed but i want to upgrade into a better subscription because they locked me out when my data threshold got overboard, now it is giving me a hard time accessing My Account..
Try shut down / restart your cell. If that don't help, try network reset. Let us know when and how it got fixed.
06-08-2026 02:45 PM
06-08-2026 02:40 PM
to clarify...are you wanting to renew or upgrade plans ?
When you activated your Public Mobile acct, you provided a valid Cdn payment card which by default, was set to autopay so you shouldn't need to manually pay unless you disabled autopay. During your regular plan renewal...it sorta looks like your account is suspended....but as long as talk/text/data are working as expected you can just ignore. The renewal will occur and tomorrow all will look normal again.
06-08-2026 02:32 PM
i did everything and I am almost frustrated
06-08-2026 02:31 PM
hi @Roland007
don't click "finish up activation". You just need to ask PM support agent to help. You can submit ticket by direct message:
06-08-2026 02:30 PM
it is a login issue but PM can sort it out
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
