Data add on
Petka
Hi i just purchased a data add on 5gb internet. When i am outside it is not working. How do i turn this option on? Thank you
2 REPLIES 2
porcupine
Reboot your phone and make sure your data is turned on
hi @Petka
make sure you don't have mobile data limit set
then try Reboot phone and click Reset network settings
if same, then submit a ticket with CS Agent using Chatbot here:
             Type the question "Ticket", Then click the following in order: "Account Management" , "Log In".
             (If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit  ticket by direct message:
