need help transferring number
Moe120
Hello, I need to transfer my number. My app is stuck to contact you and the website is also stuck to activation. I am using my other account to get some help. My number
Moe120
my app is stuck at the last stage to contact service. what do i do?
@Handy1 wrote:
@Moe120  I’ll add you the porting team number private message and they can re trigger the port request for you . But if you need support you can also use this direct link
send  a  private message   To CS_Agents
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
The porting team wouldn't be able to assist with the activation or the app issues.  As the app isn't allowing the customer to proceed any further, the number port may not have been requested yet.
