05-12-2016 12:12 PM - edited 01-04-2022 12:53 PM
just got my sim card and activated online for the 90 days plan, just can not log in my account, the Email Verification is also failed, when i use the new sim card to make a call , it said there is no talking plan
after all the proccess there is a error message showing like :
My Account
11-10-2018 08:17 PM
@mohsendadkhah wrote:Yes, I still need assistance.
The transfer was successful , however, when trying the sim card using my LG G4, it requires a pin which i do not have.
where can i get the pin from?
thanks
It is best to start a new topic as I suggested above. From there you will get better assistance in resolving the issue.
Go to Community, at the bottom choose the best category that represents your situation (Not Knowledge Base), click orange target at top "Start a Topic".
Please include as much information as you can about your situation.
11-10-2018 08:14 PM
thanks
11-10-2018 05:57 PM
Not sure if you are still needing assistance?
If you are it would be best to start a new thread. You will receive better response that way as this thread is already makred solved.
11-10-2018 05:29 PM
11-10-2018 05:21 PM
Please remove you phone number from your post because this is a public forum and anyone can get it.
To port your Virgin number to PM,
1. login to your self-serve account.
2. Select [Plan and Add-Ons]--> [Change Phone Number] --> [Transfer a wireless or wireline number ]
11-10-2018 05:13 PM
Hi
Vorgine mobile is my service provider.My account # is 528144999 in case you need it. I contacyed Virgine mobile already and they said, I need to ask Public mobile to request a transfer from Virgine to Public mobile. If this is the case please go ahead and do it
Thanks
11-09-2018 02:49 PM
@mohsendadkhah if you want to transfer in your phone number from previous provider, DO NOT cancel that plan.
You can't make any calls? What is your phone's brand and model? Did you buy it from your previous provider, prior to Dec 2017?--if so, who was the provider?
11-09-2018 02:09 PM
HI
I am new to PM. I ordered a sim card and activated but i cannot make phone calls?
what is the problem? do i need to cancel my plan with my previous company? what is the next step?
thanks
05-12-2016 12:42 PM
hi mary , i just sent you my phone number ,thanks
05-12-2016 12:19 PM
Good afternoon @leishanlin
Welcome to Public Mobile!
I am really sorry to hear that you are unable to use your services after activating your new account.
Could you please send me your phone number via private message?
Also we currently have a technical problem with our website regarding the email verification tab, please do not use this tab to validate your email. We are working on getting this resolved at our soonest, please be sure that you will not lose access to your self-serve account.
Thanks! 🙂
