Friday
my eSim is not activating and it says to contact cx support
feeling SUPER frustrated as I'm getting the run-around on this website, and it's also trying to text me to 'confirm full access' but I'm not getting any texts
Friday
eSIM cam be a headache when activating as it is not physical, can't test it on another phone or remove and reinsert
But PM should be able to help or send you another one , another QR code. You can open ticket with PM using the Orange Chatbot icon on the lower right. Type the question Submit ticket and select Contact Us to get to ticket open screen
Friday
there is a chance that the error was there because the Public Mobile esim is already installed and just not properly enabled
On Android: Check your Sim Card Manager and see if a Public Mobile eSim is there. If so, make sure it is enabled.
On iPhone: check Settings > Celluar and see if the eSIM is there. If it is, make sure the PM eSIM is set as Primary on "Cellular Plan Label" and "Turn on This Line" is toggled on
if you don't see the Public Mobile esim there, check the Welcome email, there should be a QR code for the esim for you to scan and install manually)
If the Public Mobile eSIM is there, disable or delete those non PM sim (eSIM/Physical sim).
If the non-PM sim is physical, remove it. If the non-PM sim is an esim, disable using the SIM Manager on the phone (or set as Secondary and turn off "Turn on this line" for this non-PM esim)
Then reboot the phone and click Reset All Networks on your phone and it will work. (Please note that Reset all Networks will also erase your saved Wifi and Bluetooth connections, but you just need to add them back after). Also, it is possible you have to reset it multiple times for it to work.
if it still does not work, open ticket with PM support. Just private message CS Agent at:
