11-21-2021 11:24 AM - edited 01-04-2022 05:09 AM
how do you get a ticket. i was locked out of my account cause i forgot my security password.
11-21-2021 12:52 PM
you need to Contact Customer Support Agent by CS_Agent, and Explain your issue to
them can solve your issue, they are nice Service Team they will help you 100%.
and them will reset for you,
Here’s How To Contact Customer Support Agent by CS_Agent,
Good Luck.
11-21-2021 11:41 AM
@Marie_ If you have trouble opening ticket for password reset using Chatbot, follow this will get you to ticket open screen quicker
11-21-2021 11:31 AM
@Marie_ wrote:how do you get a ticket. i was locked out of my account cause i forgot my security password.
@Marie_ -
Do you know if you ever created a Self Serve account? IF not, you can register for one here: https://publicmobile.ca/en/bc/portal/activation
Did you have more than one security question set up?
IF so, wait about 1/2 hour, as your account locks up with too many failed attempts, then open a tab in incognito mode and try again.
If still issues getting into your account, as CSA for help...
To contact the Public Mobile Customer Support Agent (CSA)_Team, there are two methods to reach them:
1 - Faster - Click the bubble comment circle on the bottom right-hand side of your screen,
or use this link to: Get Help With SIMon the Public Mobile chatbot
OR
2 – Slower - Use this link to:
Private Message to Public Mobile Customer Support Agents (CSA)
11-21-2021 11:27 AM
Here's how to contact CS:
11-21-2021 11:25 AM - edited 11-21-2021 11:25 AM
Top of page, click Get Help / Chat with Simon.
